how do i get my P3 700E past 933 mHz?
Sunny129
4,823
ok, i would go to www.cusl2.com, but their site isnt loading for me right now. so the question stands. how can i get my P3 700E past 933 mHz? i am running it @ 933 right now (133 x 7.0)...actually its at 938 mHz according to WCPUID b/cx my FSB is @ 134 mHz, not 133 mHz. anyways, i'm having no temperature or stability problems, and i am using the highest FSB : DRAM : PCI ratio i can find in the BIOS. everything is rock solid right now, so i know i can push it more...not to mention the fact that its guaranteed to OC to 1GHz, but i just cant figure out how to do it b/c i cant find any higher settings in the BIOS. help please!
Mikewarrior2
7,132
You're not setting the ram at faster than FSB speed, are you?
ALso, what bios are you using? What cooling? What program to chekc temps?
Mike
Sunny129
4,823
lol...i forgot that certain key combinations in the forums make certain faces...my FSB : DRAM : PCI ratio is 133:133:33. so the memory is running at the same speed as the FSB. i am using the original BIOS version (the one that comes with the mobo) 1.001A i think it is called. i am cooling the CPU with a Gorb and using ASUS PC Probe to check temps. idle temp = 28C, and the highest i've seen so far is 33C.
Sunny129
4,823
Thanks Mike...to be honest, the PC probe hasnt been giving me problems lately, but when i first installed it, i noticed that it was way off. i knew something was wrong when it said my CPU temp was at 14C (much, much, much colder than room temperature...not to mention it is impossible for a CPU to run even a fraction of a dergree cooler than the air surrounding it:confused: )...so i guess its off to cusl2.com to get a new version of PC Probe. hopefully i'll be able to connect to their site b/c i couldnt b4. and will an updated BIOS contain the settings i need to push the FSB beyond 133 mHz?
