Wait so it's not going back to 1.6 ghz in idle or is it just the voltage that doesn't go down? In my motherboard the speed drops to 1.6 ghz but the voltage stays the same so it's like:
IDLE: 1.6 ghz 1.368 Vcore
LOAD: 4.5 ghz 1.36-1.368 Vcore
neither would go down. once I move the voltage away from auto it will not use any power saving features. I am going to experiment with some turbo modes again and see how that goes. the voltage will do different things under load based on exactly how I use or dont use turbo so its really irritating to keep testing this over and over at different settings. plus I have to F6 every time before I change anything or some settings don't get applied.
if I do nothing but disable turbo, and set the multi to 42 then my voltage will go to almost 1.35. that with voltage on auto. if I go back to stock everything and enable turbo to 4.2/4.3/4.4/4.5 it will use 1.31 to 1.32 volts with 4 cores under load at 4.2. it will also lock up in IBT though. it will not blue screen though which it does when its voltage related though. if I just enable all 4 turbo cores to 4.2 then it normally goes to 1.304 but might hit 1.312 a couple of times. it seems stable when I do that though.
lol, and I though overclocking Sandy Bridge was supposed to be easy. if I had a board that allowed offset voltage and did not disable power saving features when manually adjust voltage then I would be able to do exactly what I am trying to do though. I cant believe MSI did not do a better job in those respects for this board.
EDIT: I just checked in RE 5 and it was using over 1.34 volts there which is WAY more than it should need. that was voltage left on auto with all 4 cores on 4.2 for turbo. it seems odd that voltage is higher in games under less load than using IBT. remember I can run it at 1.230 for 4.2 if I manually set voltage.
so at idle I think I would rather use 15 more watts at 4.2 and 1.23 then to have have it use 40 more watts than necessary under load if voltage is left on auto. sure it may sit at idle 90% of the time but that extra wattage under load can push things a bit when the rest of the system is also being pushed at the same time.
