i have a lan force nforce2 board now on which i am using onboard sound with both digital and analog speakers attached.
can i do the same to a lan party nforce 4 ultra board or do i have to choose either analogue or digital sound output?
if i have an audigy 2z card should i use that instead because it will produce better sound?
can i use audigy and one of the built in sound systems at the same time or will that not work?
what would be the best combination to use?
