Depending on your OS you could just go to system device manager, right click on your CD-ROM properties and enable auto insert notification. Or just download TweakUI and you can enable it there.
Make sure you click on the + sign next to CD ROMS and select the specific drive you want. Right click on the drive and select properties. Go to the settings tab. Check the auto insert notification box.
