how do I get AJAX out of the inside of a water bottle?
gotsmack
5,768
I bought a nice water bottle from sports authority so I can bring water to work (the water at work tastes bad). I poured some AJAX inside the water bottle to clean it out but it seems that it caked on. I got most of it off by scraping the bottom with the handle of a wooden mixing spoon, but i'm sure that there is a fair amount still stuck onto the bottom. I have tried hot water and salt.
I already tried keeping it filled with water and pouring it out every day for the last week now.
***UPDATE**
Everyone is saying Vinegar, it might work but the bottle is going to stink of vinegar. I'm just going to buy a new bottle.
Live and learn.
Thanks for the help guys.
msi1337
7,818
69
101
steps:
pour in hot water..not boiling...just hot... fill to brim...
let sit for an hour...go to your nearest dollar store and buy a toothbrush...
(alternatively you could get a bottle brush)
scrub with brush after it has soaked..
rinse out a thousand time (ajax is not good for you)..
ps. next time use dish soap instead of ajax..ajax is not meant for cleaning most plastics...and can leave a residue which will make your drink taste bad
gotsmack
5,768
Originally posted by: msi1337
steps:
I guess I'll just have to buy a new bottle then. Live and learn.
eelw
10,228
5,343
Get a steam cleaner and stick the nozzle into the bottle and blast away.
yhelothar
18,409
39
I'd also guess vinegar should do the trick. Acids are good for cleaning off bases and vice versa.
altonb1
6,432
This may sound odd, but did you try ice?
Put the ice in the bottle, then swirl it around repeatedly. medium-sized pieces probably would work best. It will be a solid substance to knock the ajax off, but ice won't scratch and/or damage the bottle.
Try it and see if it helps.
FoBoT
63,084
15
fobot.com
oh, you might also try nanobots or nanites, whatever they are called, those very small machines that do stuff
Apr 17, 2005
13,465
agreed...however, be careful as to not use the ones that feast on human flesh
