How do I get 6-channel audio with P4B533 to work?
Slugbait
No answers in General, hopefully a better result here...
I've tried everything I can think of. Default (autorun) install of drivers/apps from the mobo CD results in a dialog in the C-Media mixer that sez, "S/PDIF OUT only wroks (sic) on Headphone and 2 speakers". Ummm...the mobo manual (and everywhere else Asus advertises about this mobo) sez 6-channel requires coax via S/PDIF. Selecting 4 or 5.1 automatically unchecks S/PDIF and disables it.
Clean image drop and installing the drivers via Device Mangler doesn't work, either...tried both \Win_98SE\drv and \Win_9x\drv folders. S/PDIF isn't even detected by Windows Mixer when installing from the \Win_9x path. Other two install options shows S/PDIF Out in Windows Mixer (in the "Other" radio button), but whereas it can be selected...the OK button is disabled!!
Drivers downloaded from c-media website had an older timestamp.
Anybody know how to get 6-channel audio from this board?
System specs:
1.6A CPU (not o/c'd), Enermax 350W PSU, 512 Samsung PC2700, Compro GF3 Ti200 Personal Cinema (AGP), Voodoo5 5500 (PCI), Adaptec 2940UW, Intel 10/100 NIC, IBM 75GXP 30G (master), IBM 60GXP 40G (slave), Plextor 40TSi CD, HP 9200i CDRW, Sony 5x DVD, Win98SE, IE6 (critical updates as of July 30, 02), DirectX 8.1
Additional notes:
- Repro'd on XP...UI is a bit different, but results are the same as with 98SE
- With WinDVD, all audio options above 2-channel, and S/PDIF-out, are all disabled
- Yes, I have a DD/DTS receiver hooked up (as above, at least I'm getting 2-channel audio)
- Yes, I sent mail to tsd@asus.com...haven't heard anything back
