How do I format my hard drive with XP
BTW, it is an NTFS format. Also, I read somewhere that you could use a Windows 98 startup disk to access f-disk and it's all gravy from there. Has anyone tried this?
If you want to format-and-reinstall, just boot to the XP install CD. You'll be given a chance to partition and format during text mode setup.
If you want to format a data drive, right click My Computer, choose Manage, and go to disk management.
I have, just delete the non-dos partition. If you want to install 98 just create a regular partition.
I dont want to just reinstall windows xp. That is what the cd rom allows you to do. I want to completely erase all data off of my hard drive and then install xp from scratch. I also dont want to install windows 98. But I have read that you could use a 98 boot disk to completely erase all data off of the hard drive.
You can erase the partitions using a win98 bootdisk. But the WinXP cd will allow you to do that too. You can delete the partition and format the hard drive.
