- Dec 8, 1999
- 450
- 0
- 0
Hi guys. My friend has cable broadband service with no router in between. All was working fine, when he showed up one day and his WinXP SP2 computer was giving him the "Network cable unplugged" error. I've tried the typical suggested fixes like powering off the cable modem for 30 seconds, changing cables, changing duplex settings, but the problem remains.
All the lights come on the modem, except the Activity light which is off. There are no lights on the back of the NIC.
I even tried connecting my laptop to his cable modem, and the same thing happens for my laptop (even though I have the same service provider and it works fine at my home). I get the network cable unplugged error message. ipconfig states that media is disconnected.
We called the service provider and they say that his modem checks out fine and it must be his computer. But how can that be if my computer does not work, either?
Aside from trying out a USB connection, I can't think of any other steps to take. Do you guys have any suggestions? Thanks in advance.
07/04/08 Update
The modem ethernet port was the culprit. Connected via USB, and everything works great! Thanks a lot for your help, guys. It was very much appreciated!
07/04/08 Update
