- Apr 20, 2003
- 32,236
- 53
- 91
Basically I've had my computer running great for at least a year without doing any upgrades and I've had the mobo, ram, and cpu probably close to 2 years. Never had any problems in the past. Reciently for some reason my computer has been randomly freezing and restarting for no apparent reason. It seems completely random! I don't think it's a heat issue either. I got out my can of compressed air and cleaned out all the dust just in case. Here are the specs:
Pentium 4 1.6 @ 2.1GHz
Gigabyte GA-8IHXP
640MB RD-RAM
Radeon 9600 Pro 256MB DDR
WD 200GB w/ 8MB Cache
WD 100GB w/ 2MB Cache
some other useless stuff
I remembered I was using beta video drivers for better Doom 3 performance and thought that might be the cause so I replaced them with the latest final drivers with no luck. I don't really think I have done anything from the time my computer worked and now. Checked for viruses, ect. and it is clean, so I'm pretty sure this is a hardware issue. Also there are no BSOD when it crashes either. It just freezes/resets. It's been forever since I had to hunt down a hardware problem. Any suggestions on where to start?
Edit: I had completely forgotten I had my computer overclocked. It's been this way for 3 years. Think I finally killed it?
Gigabyte GA-8IHXP
640MB RD-RAM
