How do i figure out how powerful of a psu i need?
Nov 11, 2004
10,855
Well, PC P&C have a guide which can help you calculate power usage, but it's not very accurate. According to them, I need a PSU rated for 4000W.
RussianSensation
19,458
765
Who cares about power rating. Go with a PSU that has about 28+ A on the 12V rail. Either dual-rails (ie. 2x16, 2x18), or a strong single rail (ie. 28, 30, 33, etc.)
Thats is why often a 400watt psu is better than a 600 one.
Get Enermax 495, Powerstream 520, tagan 480, Antec 550 or seasonic S12 for insane power. Make sure you get a 24-pin compatible psu these days. With dual core processors and next generation videocards, all you should care for is a strong 12V rail(s).
smthmlk
493
the question is: do you plan on making an SLI system with 2 6800GTs or Ultra's? If yes: 500w and higher by a TOP NOTCH name brand (PCP&P, OCZ, Fortron/FSP, Seasonic, etc).
If no: get a quality 400-450w psu by a top notch brand (all of the above, including Enermax and Antec). That will do you right. The OCZ modstreams are great PSU's for the money in the 400w range, as are the Fortrons which have the 120mm fans in them. Have a look at Seasonic as well.
So as you can see, there's two groups: retardedly high power consumption in the form of 2 massive video cards in SLI, or not. The decision then boils down to finding the best PSU with the features you need at a price you're comfortable with. I would not recommend getting a "cheap brand/high wattage" psu or a "low wattage/good name brand" psu. 400w or higher will do you right and take the guess work out.
Apr 17, 2005
13,465
that psu calculator is not very thorough.
ok thanks...can you guys recommend any cases with power supply. and no, i'm not gonna be goin sli
KoolDrew
10,226
7
Depends on your parts. The PSU that comes with the Sonata is good, but if you are ocing you may want something better since I think it is rated +12v@18A
bob4432
11,726
45
i was looking at the sonata...what antec case would you say is the next level up from that?
i always buy antec if i am going to put any $$$ in a case. the 1080amg is nice and big, with a nice p/s too or titan 550
Ike0069
4,276
Sonata is a great deal because it comes with a good PSU. The PSU has 24A@+12V, so it is enough for most any system. It does have airflow limitations though. I'm going to have to mod mine because my system temp is getting too high due to the restricted air flow.
I also like the P160, but $130 without a PSU is too much for me.
Jeff7
41,596
19
Originally posted by: Green Man
Online PSU requirement calculator
That thing says I'll need about 388W to run my other PC. Granted, it's got a 430W PSU, but it only draws 190W when under load. So that calculator might be a bit off.
It would be nice if PC components came with maximum power ratings, just like most common household appliances have.
Apr 17, 2005
13,465
i'm so confused about that case. can you guys recommend me some good cases with psu for about $100 or less that would be good in terms enough wattage as well as good cooling...
bob4432
11,726
45
here you go but pick it up at a local b&m store because of shipping
or this, i have the old version and love it.
bob4432
11,726
45
Is there an easy way to figure out...cause i dont have all my comp parts yet
maybe instead just tell us what your sysem is
