How do I extend the reception range of my wireless NIC?
ibex333
I can see there are antennas for such a task, but the ones I found seem like they are designed to extend the range of MY access point's transmission. What I need is to extend the range at which I can see/detect/connect to other access points in the area. Links please?
Also, is it in any way dangerous to have such an antenna in my house/appt if I am physically close to it? Is there any effect happening similar to using a cell phone for a long amount of time? Thanks.
So you want to increase the range of your wireless adapter. This is impossible to do without a powered antenna or getting closer to an access point. How much is your budget?
Perhaps something like this would work : http://www.amazon.com/BlueProton-100.../dp/B003F6GTCO
Wifi antennas etc are harmless to you. I'd be more worried about solar radiation and other spectrums before consumer signals.
The general approach that I take for Coverage issues is the following.
The best way is to lay few CAT6 cables to central locations in the house, install Access Points, or Cable/DSL Routers configured as an Access Points ( Using a Wireless Cable/DSL Router as a Switch with an Access Point - http://www.ezlan.net/router_AP.html ), and connect them to the Main Router.
You do not want/can not/hate/your client hate to lay Cables.
Start with One affordable Wireless Router that can do WDS (the reason to start with WDS capable Router is that in case you need to add more Wireless WDS hardware the original Router has to support it).
If you are lucky and your environment is conducive to get covered with one Good Wireless Router and you are done.
http://en.wikipedia.org/wiki/Wireles...ibution_System.
Buffalo-HP-54G, Linksys WRT54GL, and Asus, 520GU can do WDS when flashed with DD-WRT firmware.
It is a good idea to start with the Buffalo since it is a High Power Wireless Router that covers more distance to begin with, http://www.newegg.com/Product/Produc...82E16833162134
Due to the added flexibility, it is better solution to choose Routers that can work with DD-WRT
http://www.dd-wrt.com/wiki/index.php/Main_Page
http://meanderingpassage.com/2007/04...on-system-wds/
Using a Laptop loaded with Wirelessnetview, do a Wireless survey, http://majorgeeks.com/WirelessNetView_d6102.html
According to the signal strength reading, identify spots that have strong signal. and spot with weak, or No signal.
Evaluate how you can cover the space and start placing WDS units.
Additional Wireless Routers in WDS Mode (Wireless Network - Configuration Modes. ) has to be placed in spots were the signal is good about Half way to the dead spots.
How many WDS units are needed? It depends on your specific environment (that is a good the reason to buying WDS units one at the time, try it, and decide on the Next step).
More about the topic (the pages bellow were written a while ago, ignore the specific hardware recommendation just stick to the principle and get current hardware)
Extending Distance - http://www.ezlan.net/Distance.html
Wireless Router as an AP - http://www.ezlan.net/router_AP.html
Wireless Modes - http://www.ezlan.net/Wireless_Modes.html
Wireless Bridging - http://www.ezlan.net/bridging.html
Hi Gain Antenna - http://www.ezlan.net/antennae.html
