How do I enable to Right Mouse Button...at work and need to save a Power Point file to HD
leeland
3,659
I am at work...and for what ever reason they disabled every computers R mouse button...so I cannot "save target as"
now it only opens the Power Point in the same window...
any way of gettting around this ? I have tried to keyboard work around for R mouse click but that didn't work
I am not trying to do anything naughty...even though I am not sure what the hell you could do with the right mouse button...but they have there reasons i guess
thanks in advance
leeland
ps i can't get to the Run line to get into regedit either....they have it disabled only when in Internet Explorer on...I am assuming that it is so users don't download music and other stuff
Joker81
1,281
View source maybe. or if you want to try click on the link and hold. drag it to the desktop then open it in powerpoint.
Snapster
3,916
Use the key inbetween the right windows key and right ctrl key after you've tabbed to the link. See if that allows the properties popup dialog.
leeland
3,659
No that didn't work...I have tried everything I can think of...thanks though guys for any help
Tell me where you work so I can come down and beat the Stupid out of your IT department.
- M4H
I know it is such a stupid thing to disable...I use the right mouse button for everything :)
leeland
obiwaynekenobi
1,971
I have no right click
no "File" in any menu,
no shut down option,
can't Ctrl-alt-del
No My computer
no control panel
I click start and it goes right to "programs" I don't get any other options
Can't use IE until I open a window, which is intended to let us use it as a "File manager" lucky for me IE is embded into XP.
Can't even use Notepad or Calcuator.
You think YOUR IT department is bad.
Shockwave
Banned
Sep 16, 2000
9,059
:confused:
I'll never talk bad about my IT Dept. again! We have the hook up, near-admin rights. And if you know the right people... ;)
Czar
- M4H
sig worthy :D
leeland
3,659
can't Ctrl-alt-del
No My computer
no control panel
dude now that sucks donkey balls....I think I would have to quit that job... :)
Hector13
1,694
You mean you can't right click a link in IE to say "Save As"? Doesn't shift-click do the same thing? I haven't used IE in forever, so I don't remember for sure, but I think it does.
leeland
3,659
your right that will just open what ever you have selected in a new window...what i am looking for is when you click on a link...to be able to save it to the HD...they have disabled R click on the mouse when you are online...thus I can't save anything to the HD...
Hector13
1,694
my bad, I must be thinking of netscape navigator... any chance you guys have that installed?
leeland
3,659
Originally posted by: Nohr
Shift-F10 is the keyboard equivalent of a right-click, if that helps any.
thanks I tried that as well, no go...I am sure they disabled something in the registry....and since i can't get the run line going (they blocked taht too) i might as well give up
