how do i enable from panel jacks for headphones?
OmegaShadow
231
hey, im having a little problem. i just brought some headphones and having problem with enabling the front panels for my headphones. i don't wanna use the back panel cause thats for my speakers and plus its more convenient for me to plug my headphones into the front panel.
so i google'd my problem and this link tells me to uncheck the box "disable front panel jack connection"
http://www.rm.com/Support/TechnicalArticle.asp?cref=TEC949416
but
this is how my realtek hd audio manager looks like
http://img62.imageshack.us/i/audiomanager.jpg/
thanks for ur help :D
i cant find the tick box anywhere lol.
corkyg
Elite Member | Peripherals
27,370
239
You must first make sure that the front panel audio ports are connected.
