How do I drive on ice without dying?
Haircut
2,248
Stay in as high a gear as possible and pretend you have an egg under your accelerator that you don't want to break
FoBoT
63,084
15
fobot.com
choose a route with as few hills, inclines/decents as possible
driving on FLAT ice isn't so bad if you go really slow and the idiot behind you doesn't ram you
good luck
notfred
38,241
4
Get a cold and stay home.
How the hell should I know? It's sunny and 50+ degrees in northern california at the moment....
lilFajita
1,313
you could just go ahead and die. that'll teach 'em.
its still not cleared up? just skip class!
GeneValgene
3,884
just don't slam your breaks.
drive slow, especially over ice covered bridges and overpasses.
anyhow, austin has done a good job of sanding and salting the roads, so you should be fine.
Hayabusa Rider
Admin Emeritus & Elite Member
Jan 26, 2000
50,879
4,268
Avoid hilly terrain and sharp curves as much as possible. Also use your transmission to brake as much as you can. That keeps the rear end of your car from turning around and becoming the front.
spacelord
2,127
...rookies.. and southerners... freak out when they get a little ice.
hell, you havn't driven on ice until you've done a donut (not intended!) on a busy road.
drive slow and take it easy.
stev0
5,132
drive slow. stop slow. excellerate slow. pretend your 80 and it's sunday afternoon :p
LeeTJ
4,899
which car is it??
i had a Mustang LX 5.0 back in the day. damn i drove that thru all kinds of snowstoms in Michigan. :)
but ya, it is hairy and you have to be EXTREMELY careful.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
My 924S has about the same power to weight ratio (150 hp, 2,700 lbs) and it's RWD too. The car did just fine driving around Pittsburgh when they closed the campus because of 14 inches of snow and ice. Just take it slowly, don't make any sudden moves, and start in second gear instead of first. If it's really bad, start in third gear. It's not the best thing in the world for your clutch, but it can keep you moving.
ZV
Eli
Super Moderator | Elite Member
8
Just drive really slow. You'll be fine.
Chains would help, too .....
LeeTJ
4,899
ZV
power to ratio compared to what??
my mustang had 225 and 300 ft/lb torque weighing about 2800 lbs. 225's on there too. it was horrible for anything wet or slippery.
GroundZero
3,669
if you don't know how to drive in the snow and ice already, there is no way some atoter is going to teach your dumb ass how to on the internet. common sense helps, but you are asking this question here, so we can rule that out.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
ZV
Compared to Jellomancer's 240SX, what else would I be comparing it with? He asked the question, and so I was replying to him. Sheesh, no need to get your panties in a wad because you're defensive about your car when someone else isn't even talking about it.
ZV
LeeTJ
4,899
ZV
ZV
my panties are fine where they are.
i didn't know jellomancer had a 240sx and he never said that 's what he had in his post. i'm the only one that posted the name of a car in this thread. and since you didn't state SPECIFICALLY who you were responding too. . .
