How do I create a shortcut for my Doom 3 mod
Lyfer
5,842
I want to create a shortcut that automatically loads my CDoom mod. Don't like to manually load the mod (regular doom3 sux).
ANother question, I enter:
seta r_displayRefresh "100"
to have doom 3 use a higher refersh rate, it works, but after I reload it I think doom 3 deletes the entry and it doesnt work anymore. Any ideas?
Thanks mucho.
BTW CLassic DOOM PWNS.
xcript
8,258
http://www.modwiki.net/wiki/Modding#Starting_your_Mod
Add the command to autoexec.cfg.
http://www.modwiki.net/wiki/CFG_%28file_format%29
skace
14,488
7
cdoom does rock. try adding "+game <mod dir>" to your shortcut but I'm not sure if it will work. Also you might be able to add +seta or -seta (not sure which) to your command line also.
