Originally posted by: illusion88
It doesn't work like that. You need to put on your glasses and go read a wall chart.
What do you mean? I can read all the lines on the wall chart with my glasses on. I thought the point of getting glasses was to be able to read all of the chart instead of only the top line.
ALL the lines? If that is correct, in theory you have 20/10 vision.
The wall chart tells you what your vision is rated at based on what line you can raed. That is how you get that number, by the chart not by your prescription.
To enter flight training, a candidate must pass a Flight Class I Flying Physical. To become a pilot, that means the candidates vision can be no worse than 20/70 (correctable with glasses to 20/20) in each eye. To enter Navigator Training, the candidate can have vision no worse than 20/200 in each eye (also must be correctable to 20/20).
Is there no way to get a rough estimate based on the perscriptions?
http://www.mdsupport.org/snellen.html
Enjoy. And let us know what your visual acuity is.
Originally posted by: Vic
Generally speaking, -1.00 to -1.50 is in the 20/70 range.
I can't see the big "E" without my glasses/contacts on.![]()
Originally posted by: SoulAssassin
I just asked my g/f what her prescription is out of curiosity...5.5 or 5.75 in one eye and 4.75 in the other. HFS...she has to be bordering on legally blind.
edit: looks like 20/200 is legally blind so she's way over that.
http://www.medterms.com/script...t.asp?articlekey=10614
Wikipedia has the chart with 20/20 type numbers marked.. No need to redo it, just use the same line on both.Originally posted by: Savij
Bump on how to read the chart.
