How do i connect front panel audio to my k7vta3?
JEDI
29,391
2,738
my case has 6 wires for front audio:
grd
grd
mic in L
mic in R
L-out
R-out
How do you connect them to the K7vta3 "Audio1"?
edit: mobo is v6
Brian23
Banned
Dec 28, 1999
1,655
I have this board, and I have no idea if it even supports such a thing. I would say to contact ecs and ask them.
o1die
4,785
The directions are in the motherboard manual. You have to remove 2 or 3 jumpers on the front panel audio connector, consisting of about 9-10 pins, located next to the onboard sound ports. Make a note of the pin positions. If you change cases or sell the board to someone else, the speakers won't work with the pins removed. The connections are pretty straightforward. One wire from the case is unnecessary, so just leave it disconnected.
Zap
22,377
7
grd
grd
mic in L
mic in R
L-out
R-out
That doesn't look standard. There should be L-out and L-return, R-out and R-return. The "return" part is just a loopback. Also, there should be a 5V/BIAS line.
