There is thermal compound residue all over the surface of my Tbird cpu. I am trying to rub it out with rubbing alcohol , but its not working. The thermal compound is arctic silver 2. The website calls it "slightly conductive" and says the compound should not make connections.
Questions
1) Would it be okay to leave the residue on the surface of the chip? There seem to be some other components on the cpu besides the core.
2) What can i use to remove the residue?
thx
Questions
thx
