how do i check my power supply which can decide what video cards i use?
rawrcakezz
16
err, title says it all? I know certain video cards require certain power supplies, how do i know how much mine already is?
brblx
5,499
look at the sticker on the side. tell us the brand, model, 12v amperage rating, as well as what the rest of your system is like and what you want to spend on a card.
zerocool84
36,041
472
Where did you hear that certain video cards require certain power supplies??? They may require certain voltages/amps to run correctly with the correct connectors but not certain brands. You post no info about what you have so it's impossible to help you.
Lunyone
482
Please give us some insight into what you want to do or what GPU that you want to use. If you can give us your current build and where you want to go, with a certain budget, than we will be able to assist you more. Your question is a bit vague, so we really can't help you out with your problem.
