How would I check the FPS in say Counter Strike. Also, how can I tell if my card is running at 200 vs. 180. I know that I control the speed but how do I know if it is running at the selected speed?
Well if you control the speed it should be going at what you say
Head on over to rage3d.com and pick up one of the various tweakers. I'd recommend Raid-On by Humus. It'll tell you exactly what the card's running at and you can change it if you wish.
I would assume you're using a tweaker program. If the program says you're running at 200 then you are. Its not a trick question. As for counterstrike....I forgot the command ...but I would raise the max fps in the game so it'll be a bit smoother than when its capped at 70.
i cant remember the command to bring up only your fps, but the command to bring up your fps AND show your ping rate plus some other stuff is net_graph
use net_graph 3 so you wont get slowdown
