How do I capture a MPEG4 picture?
madeupfacts
692
I tried print screen and pasting it on paint, but it doesn't seem to work. I just want to screen capture one shot of a divx video file.
thanks if anyone knows the answer
madeupfacts
692
Originally posted by: her209
Turn off overlays.
still doesn't work. The file is a .avi file. Plays under windows media player and says its uses divx codec. any ideas anyone?
HN
8,186
4
open whatever player and open video file. pause player.
open another instance of video player and play file. take screenshot from this instance.
keyloans
Use software "Capture WIZ" carck of it can be found at [link deleted] ... it works well for capturing pictures and vedios.
keyloans,
Welcome to AnandTech Forums. We hope you enjoy yourself while you are here, but another recommendation, suggestion or even a hint about using illegal software will be your last post on our forums.
AnandTech Moderator
KLin
30,429
746
Originally posted by: keyloans
Use software "Capture WIZ" carck of it can be found at EDITED ... it works well for capturing pictures and vedios.
Please don't recommend someone using pirated software :roll:.
