How Do I bypass VHS copy protection
ComputerWizKid
1,187
I'm trying to convert all of my Disney cartoons that are from the late 1980's early 90's (or older The cartoon not the tape, Duck Tales Rescue Rangers and more) But I tried two VCRS one was a good one a Sony which did not allow me to record the tape onto my computer (I'm using Sage TV and it just says ("No Signal") And I checked all of my cables and they are fine because as soon as I cancel the record the picture comes back. I tried one of my cheap Walmart (Orion) VCRS and that worked but the tape is in poor condition and I would like to use the Sony one Because it's older and handled the tape better. and overall had a better picture. So is there a software solution to do what I want? or do I need a piece of hardware? My Capture card is a Hauppauge PVR-150MCE Thanks
krotchy
1,942
Typically to record the output from a VCR or any other protected composite/s-video source you are going to need a time base corrector. Essentially the output is deliberately sent out slightly out of sync in such a way that TV's and other devices will still display it accurately, however recording devices tend to have difficulty with syncing the signal.
I purchased one at my old job that was the size of a hard drive roughly, and that sucker was 350 bucks. Unless I am confused with what you are doing that should do the trick, but please dont spend that much money on my word alone :p.
tw1164
3,995
You can pick up ducktails, and rescue rangers on DVD for $20 a season. I would think about just buying it for the quality vs an old VHS tape.
ComputerWizKid
1,187
I'll try the coax input did not think of that the tapes are not HI-FI Stereo anyway (Says the VCR and the label on the tape, Plus my ears can tell stereo from mono)
Oyeve
22,043
875
I use my Sony vcr from the late 80s. One of the last with white-clip circuitry. Thats how macrovision works, VCR maker remove some circuitry that allowed macrovision to fubar copies.
