How do I attach 80mm Plastic grill/filter covers? I just got two from 2CoolTek that I want to use over the intake and exhaust blowholes I cut in my Enlight 7237. The actual holes are just a tad under 80mm. I'm currently using metal finger guards and 80mm fans held together with sheet metal screws, lock washers and bolts. The holes I drilled for the screws line up perfectly with openings at the four corners of a grill/filter.
Although I like the "industrial" look with the metal finger guards I think the grill/filter covers I ordered will give my case a more finished, professional look.
If it helps, take a look at the grill/filter covers here.
