I'm suposed to apply the grease only to the area where the P4 is going to make contact........
also will the grease dry?.....
if so How do I remove the heatsink with out ripping out my p4?
Originally posted by: OulOat
You can apply thermal grease and remove thermal grease by shouting at it. Just remember to make the following face when shouting ... :|
Yeah, shouting always helps, especially if you're having a hardware problem 😉 If you are having problems, then your computer should know it is being bad.Originally posted by: GonzoDaGr8
I'll have to try that sometime. 😉
