Hi how do i access recycle bin from dos... some thing screwed up when i formated and installed winxp... all my files that i backed up to my 2nd hdd is missing.. but the space is still used... and when i click "empty recycle bin" when theres nothing.... it says "are you sure you want to delet 19 files" so i suspect the files r in my recycbin... anyway i can retrieve my files from recycle bin from dos?
thank you
thank you
