How do hardware review sites get those shots of CPU cores?
desura
4,627
129
101
Like this one from Toms Hardware?
2timer
1,803
How do hardware review sites get these shots of CPU cores?
Well, first a paparazzi hides in the bushes outside of the CPU core's house, like this:
Then when the CPU core comes outside to drive to the store, the paparazzi jumps out of the bushes and snaps a photo before the core can get in it's car!
Just kidding. Actually I have no idea, that's a good question! :)
ShadowVVL
758
I believe it:).My guess is they get them from from the manufacturer but I could be wrong.
Haserath
793
Pretty sure Intel/Amd have to sacrifice a wafer. They shave a few layers off then take a photo of it and use photoshop.
I might be remembering wrong.
ViRGE
Elite Member, Moderator Emeritus
167
No, that's basically it. There's no practical way to get a shot like this from a finished product. All of these good shots are coming from the manufacturer.
ghost03
372
That sounds about right.
Alternatively, at a guess, they might just use infrared cameras and shift the color spectrum. Silicon is transparent to infrared.
Idontcare
21,110
64
They don't have to sacrifice the wafer or the chip. They (the manfucturer or foundry) just take a wafer to a microscope tool mid-production and take photos of it. Then they put the wafer back into production.
Most micrographs of silicon dies that we see in the public are not of a chip that has been fully processed, they might still have 6 metal levels to go before they even leave the fab.
We take pictures of wafers all the time as routine analysis for yield enhancement. If it was destructive then that would be counter-productive.
Now it is true you can get the images through destructive means such as teardowns on Chipworks. But that is expensive (~$2000) and I guarantee you no one does that just to write an internet article on a review site like Toms.
desura
4,627
129
101
So what's with the colors? Is it like added for effect or is it really needed as part of the mfg process?
2timer
1,803
I think it's s added to highlight the specific components. Otherwise everything would be as monocolor and confusing as looking at a tiny circuit board.
Or maybe it's part of the lithography process? :hmm:
Idontcare
21,110
64
The colors are usually real, not added, but they are not "real" in the sense of the colors you see on a painted wall. They are more akin to the color you see when looking at a peacock's tail feathers or from soap bubbles.
Also the same thing happens with butterfly wings.
It is called thin-film interference. The different colors in the silicon die image are due to the various structures you are looking at having different dimensions and materials composition, changes the physics of the thin-film interference which then changes the color.
Figure 2. White light incident on an oil film. A colorful interference pattern is observed when light from the sun is reflected from the top and bottom boundaries of a thin oil film.
StrangerGuy
8,443
124
Why would manufacturers not release die shots? They don't divulge any critical information and corporate spies would have much more indepth information already.
Phynaz
10,140
819
Apparently they do. Remember when AMD was releasing obfuscated BD die photo's? They specifically said they didn't want the competition to glean any intelligence from them.
Tsavo
2,645
37
I wonder how many Libraries of Congress they can fit on a 3770k die.
Relative scale is important in order to comprehend sizes of things.
pm
Elite Member Mobile Devices
Jan 25, 2000
7,419
22
Back when I worked on Itanium 2 9000-series (codenamed Montecito) and was giving a presentation at ISSCC, we wanted some good die photos, so we took a few dies that we stopped fabrication at something like metal 4 or metal 5 and took them over to Colorado State University and they took the photos using a conventional optical microscope and then they email'd us some really massive .TIF files. As Idontcare said, the colors are not false-color - they are thin-film interference patterns. You can see them with the naked eye.
