how do disc breaks work?
dan150sp
i would be obliged if anyone could tell me the proper functioning of dics breaks in a bike. how does it work and why is it so good. anyone knows??
If disc brakes are anything in a bike like they are in a car, you have a disc with a brake pad on each side. When you apply the brake, the pads clamp down on the disc, thus slowing it down 🙂
/me hopes disc brakes in a bike are similar to car's disc brakes 😀
Originally posted by: Brutuskend
Biggest advantage IMO is, if your wheel goes out of true is will NOT effect your brakes!
"if your wheel goes out of true is will not?????????????????????????????????????????????????????????????????????"
I'll help scrounge for a little more info. How many econobox imports use rotors with cooling fins as shown here? Every one I've seen pulled apart has only a single, thin disc that is prone to warping, and generally can not be resurfaced. I've NEVER had a vented disc that uses cooling fins, warp on me. Seems the bigger, beefier rotors would be cheaper, and less problematic in the long run.
