how do cities get billed for street light electricty usage?
OutHouse
36,410
616
is there a hidden meter someplace for a grid? or does the electric company count how many street lights there are calculate each bulbs wattage then look at the sunrise/sunset charts and charge the city for the hours of darkness??
OutHouse
36,410
616
really? thats how they get billed by how many lamp post? does the same go for stop lights?
imported_weadjust
1,561
You can have a street light installed on your property where I live. I think the cost is 12.95 a month for the service.
Eli
Super Moderator | Elite Member
8
Interesting, I would have figured it was based on kWh just like the rest of us, but deeply discounted.
altonb1
6,432
I work for an energy company, so I'll see if I can find out the definite answer when I'm at work tomorrow.
KMurphy
1,014
There is a feeder to the distribution panel the lights are fed from. The feeder to the entire distribution panel will be metered; not each individual light. The city pays for kWH's used.
Cristatus
3,908
Also something else to consider:
You have multiple telco companies, but when you choose one or the other, they have a direct wire to your house (ok maybe not direct, but approximately direct).
But what about electric companies? How do they set out their wires?
ElFenix
102,402
8,574
afaik, you only have 1 phone wire and 1 electric wire coming into your house (because multiple ones get multiply expensive and don't need to be there because you only need 1 of each) (and the phone wire actually carries 2 lines).
in 'deregulation' there is a monopoly that owns the local lines. they're still regulated. the company who is your telephone provider or your electric provider leases the lines or is allowed by law to use the transmission lines and you pay the fee directly.
mobobuff
11,099
Same with the internet infrastructure. A company owns all of those lines, but doesn't necessarily provide the data.
FoBoT
63,084
15
fobot.com
that is an option with the electric co-op that provides the electricity to my home
for $6 per month, i can have a "yard light" which is the same as a street lamp on the pole in my yard, that feeds electricity to my house
but i moved to the country/BFE to get AWAY from light pollution (among other things) , so i choose not to do that
Rubycon
Madame President
Aug 10, 2005
17,768
485
Yep it's pulse monitored.
Some muno's have meters on the intersection j-box. These have been replaced with transponding units so the vans drive by and get the count and amount, etc.
In remote areas where power failures can last for weeks and salt water makes a mess of wiring, outdoor lighting is accomplished with betalamps. Google "traser" for more information.
There was an airport in Alaska that used them for runway lighting for a while! :Q
