how do barcodes work?
Semidevil
when I was in korea, I stayed in the dorm room of my gf's brother dorm room.....and to enter the building, the students had to swipe their ID card to open the door.
My gf's brother, then took a regular plastic card, and taped a piece of paper w/ the copyof the bar code, and voila, it opened the door....and gave it to me...
I'm wondering, how did he do that? it's the barcode with the thick and thin lines.....with those, do you just copy it, and it will work?
Originally posted by: Semidevil
what about the ones without the thick/thin lines? how would I copy that? haha
what barcodes dont have the thick/thin lines?
magnetic strips on cards??
those are magnetic...
MIKE
MIKE
'3-D' barcodes are more like a series of spots. Look at a UPS package for an example.
Talking about 3D barcodes, a series of patterns? At least I think that's what they're called... yes, copying them should also work fine.
Anything that reads anything with a scanner such as a barcode scanner can work from a photocopy.
Some barcodes are just the black lines and nothing else. Some can be infrared encoded which makes them impossible to copy. Our badges at work are like that.
FOr normal barcodes you can get software that you enter some info and it prints the barcode for you.
MIKE
You mean 2-d barcodes, not 3-d. that is, unless you found a barcode that has some sort of height to it, which I haven't see yet 😛.
2-D barcodes are a PITA to work with, btw.
same idea... just put it on a photocopier and it will copy. your paper will look blank but just because you can't see them doesn't mean the lines aren't there. voila, open sesamé.
MIKE
They're likely referring to the PDF417 symbology.
You don't even need software; all you need is a font and a suitable printer.
