How difficult is SQL to learn?
Nitemare
35,461
4
Got an interview doing AIX and SQL support yet my only experience with SQL is searching a database for what SQL error messages really mean.
BChico
2,742
Nah its not that bad, it a high level language, so it all makes sense.
The hardest things to learn are inner and outer joins i thought, but once you get the hang of it it makes sense.
rh71
52,844
1,049
I first learned it during an MIS class in college. Read a book and once you've got the syntax and "commands" it's pretty easy. If the job descrip doesn't require previous experience, you should be ok after a little bit of reading up.
jdini76
2,468
all you need to know is:
select
from
where
After that you can search the internet and help files for other syntax.
NuclearNed
Raconteur
May 18, 2001
7,887
383
SQL is not difficult compared to actual programming languages like C++. One nice benefit it has is that a SQL command roughly reads like a sentence in English.
Tea Bag
1,575
It's a very simple language to learn if you are familiar with the concept of a RDBMS. You can construct complex query results by writing simple statements. There are alot of free resouces out there as well. Based on your programming experience, you should be able to work your way around with SQL in about two weeks, give or take.
blackdogdeek
14,453
10
select
from
where
imo, the other 2 most important commands are:
insert
update
with those 3 you can do the bulk of data manipulation.
kalster
7,355
sql is easy, database normalization is interesting , but if you are supporting it, you probably wont need to know that, i personally found databases to be very mechanical/boring on the whole
Nitemare
35,461
4
select
from
where
insert
update
Thanks for all the tips, interview will probably be tomorrow
Utterman
2,147
If you can get this joke, then you can do SQL:
> "SELECT * FROM users WHERE clue > 0"
0 rows returned
DaShen
10,710
Inner and outer joins are the only thing that is somewhat tricky about database design and SQL. It is quite easy to learn. I would say take half a day to get the major concepts right.
Inner joins only link up exact matches.
there are 3 outer joins. left, right, and full
left - inner join both tables but include all "left" table that aren't linked to the "right" table
right - same but with "right" (subjective to your design)
full - include all left and right not included in inner join
then there is the cross-product
all records are matched to all records in other table. (N*M) or (N^2) records produced. not efficient.
I suggest you use something like MS Access and test a few things in a book or something. You will pick up the full concepts very quickly.
DaShen
10,710
0 rows returned
:thumbsdown:
3/10, but nice try
gsellis
6,061
SQL for Dummies is a quick read. Should have it at the library for "free".
