Originally posted by: jumpr
Depends which one it is. My old 1.6l Sentra had a front and a 'rear' (exhaust) O2 sensor. The front was easy as PIE to replace, the rear was a bit more difficult. How do you know it's an O2 sensor? Have you run the OBDII scanner at Autozone or some place similar?
Originally posted by: NutBucket
O2 is about $80. Dude, $180 for timing belt is CHEAP. Be happy🙂 Uhm, get a crow's foot style wrench and a breaker bar. It'll make it much easier.
Originally posted by: godmare
Spring for an O2 sensor socket
Autozone will let you borrow one for free if you don't want to buy it.
I dont mind purchasing stuff for the car as i hear it's only like 7-10 bucks.
what is the difficulty level ?
Can i just splice the old wiring into the new sensor ?
Yeah, AFAIK, if you buy an OEM snesor, the wiring harness will basically just plug into the wires from the car.Originally posted by: brtspears2
I say on a scale of 1-10, I say 3. Worse part will most likely be getting under the car or finding the sensor. I suggest you to buy one that works for your car instead of getting a "universial" one. I cannot confirm this, but I was told that the universial o2's might interfere with your engine computer.
Originally posted by: TechnoKid
New bosch O2 sensor will run approx $105 retail.
Not if you want an OEM one. Why do you keep asking the same question? Figure out how much OEM ones cost, add in approximately 1-2 hours of your mechanic's labor charges, and figure out yourself if it's a good price or not.Originally posted by: isekii
is 360 reasonable for o2 sensor replacement ?
I can purchase o2 sensors at autozone or something right ?
for one sensor, no, for two, maybe, but thats only if you're using overprice dealer OE parts.
it seems BOSCH or denso are the only sensors i see for the nissan quest as well. can't go wrong with either of them, both bosch and denso are OEM for O2 sensor for a lot of car makes.
Okay. Figure out how much a Bosch sensor costs, or an OEM one if you're going to take it to a dealer. Then, add in your mechanics standard per-hour labor charge, for approximately 1.5 hours. If that is less than $360, you're getting ripped off. If it's about $360, then your mechanic is being truthful.Originally posted by: isekii
I was asking for the going mechanic prices for an 02 sensor replacement.
The hell you mean why am I asking the same question.
Noone answered whether 360 was reasonable or not. 😛
yea the only ones i'm pulling up are denso and bosch as well.
I don't mind splicing if i have to but I owuld rather do a plug and play sort.
