How difficult is it to crank a modern engine manually?
imported_goku
7,613
How difficult is it to crank a modern engine by hand? I heard that in the old days that people would break their arms trying to crank an engine, why is that? How difficult would it be to crank the engine with your legs? How much torque does it require to crank an engine? Something like 100lbs or 200lbs of torque, right?
imported_goku
7,613
Well I had an idea that you would basically put a bicycle pedal of some sort in the car so that if the battery was dead, you could basically crank the engine your self from within the car..
imported_goku
7,613
Originally posted by: PHiuR
yeah, it's called pop-starting your car.
You can't do that under two circumstances.
1. If you're on level ground.
2. If you've got an automatic.
3. If you don't have balls.
XJustMeX21
1,606
Or if your sitting at your computer 24 hours a day making stupid posts every 5 minutes.
Feb 19, 2001
20,155
23
bingo!
OOBradm
1,730
according to my calculations, it would take 1.5 man watts to power an engine for an estimated time of 5 seconds, notwithstanding any air resistance or fatty resistance
yhelothar
18,409
39
The way to crank an engine by hand is the roll start.
You push the car to build kinetic energy.
You press the clutch and put it in first gear, or reverse if you're going in reverse.
If your car is moving fast enough, you drop the clutch. The kinetic energy of the clutch spinning in first gear will crank start the engine by applying torque to the flywheel.
bobsmith1492
3,875
Unfortunately, this only works if your battery is charged enough to charge the fuel injectors; otherwise, you're sitting dead in the water. That's just from personal experience, though...
Maybe you just need a HUGE amount of energy to fire up the alternator, start the car's computer, start the fuel pump, charge the injectors, start the spark, and go from there?
Zolty
3,603
If you actually want to test this lift your manual transmission car off the ground to a comfortable level, remove one of the drive tires. Now you will want to fashion a lever or crank on to that drive tire and crank away, if you think it is easy then you haven't put the car into first, you need to do that.
XJustMeX21
1,606
Yes and if buy some means it starts, keep a firm hold on the crank. ;)
EarthwormJim
3,239
I doubt it would be any harder to crank a modern compared to an older one, if there was a hand crank implemented. In fact when on a lift and my car is in 1st I can crank the engine with as little as 50 ft-lbs.
Modern engines are much lighter and have lighter rotating components.
People broke their arms in the past from kick back. If you don't remove your hand fast enough when rotating the crank, it'll hit you very hard once the engine starts.
ForumMaster
7,792
why would you do that? why not simply use cables to start the engine like any other sane person would?
doh, i answered myself.
Colt45
19,720
Originally posted by: blahblah99
If you remove the spark plugs, you can hand crank the engine with a ratchet.
Even if you don't remove the sparkplugs you can crank it with a ratchet. just not as easy
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
121
You know...for someone who thinks this thread will be "locked in 5...4..." and who thinks this "a stupid post"...this is your 3rd reply, why bother coming in?
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
121
It wasn';t the trying to crank the engine that did it......it was the kick back when the engine started.
exdeath
13,679
10
Uhm people broke bones once the engine started and they didn't let go of the crank -_-;
Modern engines use much higher compression ratios along with electronic fuel injection, etc. Without a battery charge you would have to turn the engine over by hand fast enough to get the alternator going, and that I don't think is possible.
Physically it doesn't take much to turn, and certainly much less with a large crank and possible gearing.
Just sticking a ratchet on the crank pully nut is sufficient to physically turn the rotating assembly, and is done often when pulling out flywheel or clutch bolts one at a time from under the car, etc.
lupi
32,539
260
:laugh:
