- Sep 28, 2001
- 8,464
- 155
- 106
I am posting this here.
I am thinking of getting some big aluminum heatsinks to mount LEDs on it.
The problem is I'd need to drill holes and tap the heat-sinks to be able to put screws in there.
I saw some videos and learned that it is possible using a normal (corded) drill and then hand-threading the treads with thread cutters. I do not own a drill-press/bench.
I know there are complete sets with cutter inserts and manual thread cutters available.
How easy is it to drill holes and then cut the threads..or should I have that done by some professionals? (Otherwise I don't have a problem with DIY, I just never did metal-work, hole cutting etc.. obviously I don't want to screw up the heatsinks)
