Info How did you get rid of bedbugs?
Ichinisan
28,298
1,235
IIRC if you use high percentage isopropyl alcohol, it also works. Put a ton in a spray bottle and get all the seams of the mattress that could be possibly storing the buggers.
Yes. But studies shown that the contact needs to be a very high concentration; beyond store level. Then it's very effective but very dangerous to human and animal health too.
I use 99% pure isopropyl to clean electronics. Doesn't matter if you get it on yourself or spill it. The stuff evaporates in seconds. Dries waaaaay faster than water does.
Reactions: highland145
Raincity
4,477
12
Really depends on how bad the infestation is. Using a pro that uses heat treatment for a day is the only sure fire way to get them all. Needs to be a treatment like this.
I am not endorsing this extermination service in the video but using it as a example on how it should be done.
Muse
38,409
8,700
Surprised a black market for DDT hasn't sprung up.
I think there is some around, but of course it's been totally banned for many decades.
IIRC, we used to have it around the house in the 50's, maybe 60's. Smells nasty.
deadlyapp
6,622
720
Exactly. 99% alcohol is easily available and evaporates nearly immediately. Yes if you drink it it'll kill you but most people aren't that idiotic.
Oyeve
21,995
854
My GF had em last year. Her daughters room was the worse as she probably got em from college. My poor GF was bit to hell. Shes real sensitive that way. Mosquitoes love her as well. Anyway, she called the pros, came with a dog, sniffed em out. She had to take apart the whole apartment and beds and they froze em out and treated everything. She was banned from my apt for a while. As a precaution I sealed and treated my mattress.
TXHokie
2,557
173
Fought bedbugs for a couple months many years ago. Here's what worked for me:
Lost a couch and a bed boxspring since we didn't want to risk trying to salvage it. The only bedroom furniture we tried to save was the wooden bed frame that I took apart every time there was a sighting of remnant bedbug during the weekly check. Put the mattress and boxspring in a nice bedbug proof cover (don't get the cheap plastic stuffs, it will just tear and make too much noise during sleep and you'll end up buying it twice). Kept furniture and bedding in the infested room to minimum and 2 ft away from walls and put DE around the walls perimeter. You don't want them getting into the walls and infect other rooms but it would have to be a major infestation to start getting into walls. I only had the bed and simple night stand left for easy clean up and cleared out all tables/books/dressers/closet. Our sons spent 2 months changing clothes in another clean room and only slept in that room. Moved all the rest of the furniture into garage storage during the treatment. Did the mattress check daily/weekly for any signs and if I see them, time to take the bed apart and clean every nook and cranny of the furniture and vacuum the entire room. I ended up taking the bed apart to clean 3 times and the third time, decided to paint over corners and crossbars with a layer of acrylic paint to seal in any possible hidden place in the cracks for them to hide and lay eggs which seems to have done the job. The check and clean rinse and repeat took 3 months before I stopped finding trace of bedbugs. It's been said that you don't really get rid of bed bugs until you stop seeing them for 6 months. Every time you see one, the clock resets. The chemicals are useless since they don't really seep into cracks where they hide and lay eggs. My only chemical used was 99% alcohol in a spray bottle for instant visual kill.
I did look into getting exterminator pros but they start at $500 and can run up to $2k and they also can't guarantee you won't get reinfected. You end up doing most of the work anyway with isolating beddings and laundry. I did that making sure everything gets into extended drying cycle and stuffs in separate bags and stored in plastic containers. That one encounter with bed bugs scarred us all pretty good and now whenever we go to hotels, that's the first thing we do is check the hotel mattress for signs.
lxskllr
57,981
8,219
I sleep in my truck. I started that years ago before bedbugs were exploding cause I'm cheap. Now it's a prudent self protection routine.
rh71
52,844
1,049
Twice we thought they were bed bugs and they weren't. Be absolutely sure before you upend your entire floor. Does the room have carpet?
Jun 18, 2000
11,155
733
There's a new pesticide that uses bacteria spores that supposedly kills the entire colony. I remember reading about it a few years ago. I guess it's been commercialized. Look for an exterminator that uses it. A quick Google search says its called Aprehend.
shortylickens
80,287
17,079
Theres only one way to be sure
Reactions: ctbaars
CZroe
24,195
857
Don't know who told you that. I've gotten as high as 93% from jugs at the drug store (91% is more common) and 99.9% from Lowe's Home Improvement. I keep 99.9% Electronics Cleaning Grade isopropyl all over the house for cleaning flux, cleaning old videogames, cleaning the 3D printer bed, etc. Probably going to be ordering this stuff by the gallon when I get a UV resin printer.
Unless you are doing something stupid with it that I can't even imagine, 99.9% isopropyl is not notably more dangerous than your typical drugstore 91%. It's just rubbing alcohol that evaporates even faster with less water in it and no additives for restoring skin oils.
Captante
30,316
10,814
Folks tend to injure themselves accidentley starting fires with that stuff ... not sure how they manage but they do it.
Maybe spraying it over a lighter ??? :p
Also it only kills bugs it gets directly on and has no lasting effect so while it can be part of the solution, by itself it isn't getting rid of the little fvckers!
12,613
Wonder how well this stuff works for bed bugs: https://www.ebay.ca/itm/Cyonara-Bed...801776?hash=item4d916511b0:g:naUAAOSwCm9crjHJ
Amazon has it but it's over $200 so Ebay is better bet.
I've used it for spiders, it targets pretty much all bugs as far as I know. It leaves a residue behind so it's continuous action. For bed bugs I would put holes between each stud in the drywall and spray inside each cavity too. Spray inside outlet boxes etc, get all the crevices you can. Get baseboards etc. Avoid drywall surface, because it will probably leave streak marks (you mix with water so it's like spraying any other liquid). I would avoid doing the actual bed, like do it during an infestation but I would avoid it as an every day preventive just because you probably don't want to breathe that in every night. It's relatively safe though, it has kinda a fruity smell and the MSDS is decently tame. It's considered safe for use in food prep areas as well.
It's bad for reptiles though so if you have any as pets you may want to avoid it.
Reactions: Captante
Captante
30,316
10,814
"Cyonara"
Wow that's special... :rolleyes:
It might work despite the unfortunate name but unfortunately again everything I've read on the topic (from sources without a stake in the game) has said ALL pesticides are rapidly becoming less effective on bedbugs. That includes stuff pros use which are far stronger then consumer grade products ... also usually much more expensive!
