Originally posted by: LoKe
That's an IE feature, I believe. In Firefox, it's save link as.
An MP3Originally posted by: Iron Woode
what is it you are trying to save?
if you are using IE then your browser is having issues.Originally posted by: JDrake
But I can't even save pictures or anything else
Ok well how do I fix themOriginally posted by: Iron Woode
Try Firefox as even most sites that disable right-click can't stop firefox.
Originally posted by: HomeAppraiser
FireFox? Try right click "Open Link in New Window" then right click "Save Page As" to save the image or mp3.
Why switch to a new browser, to only have more problems?Originally posted by: HomeAppraiser
Fixed
Something like this (just one example, don't think I made my entire basis of nonfirefox on that :roll: ) is enough not to use FF. I've used IE for over 8 years and have had almost no problems and nothing severe that would require a reinstallation or anything like that.Originally posted by: GeekDrew
Fixed
What potential "more problems" are you referring to?
I have been using FF since it was FireBird. I had to use IE6 because of a fussy website a few months ago and bam I got hit with that damn WMF exploit. I haven't used IE since.Originally posted by: JDrake
Fixed
Why switch to a new browser, to only have more problems?You might want to try an alternate browser (either the aforementioned Firefox or Opera). Completely dismissing anything based completely off another's opinion (individually or collectively) without weighting your own personal experience is asinine - especially considering the cost factor (free aside from one's time).
- Posting in the wrong forum? Check.
- Dismissing those solutions offered? Check.
- Continuing to make uninformed choices? Check.
If another's opinion is truly that significant, my own personal experience has shown either of the above mentioned choices to be a much better, more robust solution in nearly all cases.
This is not a thread asking for browser recommendations, I would just like to know how to fix it in IE. Thanks
When you're twelve, six months seems as though it's a long time.Originally posted by: JDrake
I've used the internet for a long time and have used many different browsers and none can compete with IE, IMO.
