Originally posted by: BroadbandGamer
Did you move the little switch over on the component cable? Did you go into the console settings and change it to 1080i and widescreen?
Originally posted by: SickBeast
Maybe you should read the HardOCP thread and/or PM the author to find out how he made it look so good. You can make the Xbox upscale to 1080i apparently.
Rage187, you are lucky to have such good hardware before you grow old and have children, thus making you unable to have time or money for computers.
/parody.
Originally posted by: JRW
http://www.hardforum.com/showthread.php?t=973982
The 2405FPW lacks the ability to properly scale and properly display the aspect ratio of material sent via a component cable.
A good transcoder will be able to take the HD input signal and send out a VGA signal with the correct resolution and aspect ratio.
I.E. if you were to use a transcoder for 1080P, the image would not be stretched on the 2405FPW if the 2405FPW has its settings tuned to 1:1 scaling.
You should also be able to use aspect scaling for 720P.
The transcoder turns a signal meant for a TV into a signal that can be understood properly by the 2405FPW.
