These days a tempature above 50c is bad for your processor however, some graphics cards namely the GeForceFX5900U can reach up to tempatures of 70c and is considered normal!
The actual reading of the GPU temp is likely done via a diode on the die which would be higher and MORE accurate than a low reading socket temperature for your CPU.
