Safety isnt an accident
In the world of hot rods, customs and kits we stand miles above the crowd. As the only replica company that has a dedicated racing series, we speak from a unique perspective.
We have a company that is single-minded in our passion for racing and performance, so safety is our daily religion. You can trust our products because the chassis that you build as a hot rod project is the same one that our team trusts with their lives on the track. Safety is a combination of
good engineering, correct materials, and careful construction.
The legends of the 60s were built not only from racing victories, but from tragedies as well. Back then, many basic safety features were either not used or not available. The Mk4 is stronger, faster, AND safer than the original cars.
bullet
Low vehicle center of gravity and balanced 45% - 55% weight distribution
bullet
Energy absorbing tubular steel frame and aluminum chassis panels (not fiberglass)
bullet
Front and rear energy-absorbing crumple zones
bullet
SCCA-derived footbox steel tubing protection and cockpit steel surround structure
bullet
Side impact bars and beefy plate steel door hinges. Frame mounted doors
bullet
Externally mounted and shielded fuel tank with fuel pump impact shut-off switch (from the Mustang donor)
bullet
Collapsible steering column
bullet
Driveshaft safety bars
bullet
3 point, 1.5 or 2 OD, .120 wall, mandrel bent, frame-mounted drivers roll bar (optional passenger roll bar available.)
bullet
3 Simpson brand, racing H-harness for both driver and passenger.
bullet
Vintage components that are individually FMVSS compliant (ie. lighting, carpets, seating material, safety glass, etc)
bullet
Manufacturing controls that maintain high degree of consistency in welding and fabrication
bullet
Acceleration, turning and stopping abilities above almost any current production vehicle
Stop on a dime
And get change
The ugly truth is that most kits, hot rods and customs handle terribly. The artistry and strength of the Factory Five Roadster chassis would be a waste without an equally well-designed suspension. Computer simulations and hundreds of hours on the track under the most extreme conditions have helped our engineers design a world-class suspension that simply works great.
Front Suspension Base Kit
Fully independent front suspension utilizing unequal length upper and lower a-arms
High-end Koni mono-tube adjustable coil-over rod-end shocks
Uses donor Mustang front lower arms, spindles, and brakes
Optional tubular steel lower control arms
Front Suspension Complete Kit
The Factory Five Racing Mk4 complete kit includes the entire front suspension assembly and Ford brakes.
Includes Ford GT brakes with 11 rotors, twin piston calipers, and stainless steel brake lines, fittings, and fasteners
Includes brand-new spindles and tubular control arms
Brakes/Wheels
Rear end and brakes can be used from a Mustang donor car. We alsosell brand new 8.8 Ford rear ends with Mustang brake kits.
We offer an optional Halibrand replica wheel that is affordably priced and in the correct sizes/backspaces to work with our car.
Rear Suspension
The Mk4 Roadster Chassis Kit is delivered ready to accept bolt-on rear suspension components in one of three (3) rear suspension configurations:
1. Four Link Rear Suspension
Our standard 4-link suspension comes with custom anti-squat geometry and ready to accept Ford Mustang 8.8 solid axle donor rear suspension parts. About half of FFR Roadster kits are shipped with the affordable standard 4-link rear suspension, which is a great performance street car suspension.
2. Three Link Rear Suspension
The upgraded 3-link rear suspension is standard in Mk4 complete kits and all FFR Challenge Series cars. It includes the frame brackets, panhard rod, control arms, coil-over shocks and springs. Recognized as a proven and worthy upgrade to the standard Mustang 4-link, this suspension eliminates any bind and provides an amazingly predictable ride at the track or on the street.
3. Independent Rear Suspension
Our Independent Rear Suspension upgrade is designed for those looking for the most comfort and authenticity, and can be added to either the base or the complete kit. It includes a welded-in cage, upper and lower tubular control arms, high-end Koni mono-tube rod-end coil-over shocks (matched to the fronts), and custom assembled axles and CV joints. The IRS option for the Mk4 kit requires the 8.8 center section (from a 1989-1997 Ford Thunderbird), rear spindles, and brakes.
