How close can I cut it with a VGA heatsink and a soundcard?
Ichigo
2,158
Say the fan ends up being mere centimeters away from the soundcard. Is that a cooling problem?
GalvanizedYankee
6,986
Only one way to find out for sure :) Try it.
Rule of thumb: The sucshion side of the fan should not be closer than the depth of the fan
to any flat surface. So.......25mm would be OK...Maybe.
...Galvanized
