GoodEnough
Is there a tester? Can the phone display this?
Like to verify if the cell phone battery I bought is actually 3000mAh ?
Hook a load to it that drains it at exactly 1 mA per hour. See if it lasts for 3000 hours.
It's the only way to be sure.
it's rather easy.
1) take battery out.
On the battery is a code. that code tells you. IF you want to test it put it in the microwave for 1minute.
Username humors me
What do you think it means? :biggrin:
I know how to measure its drain, but not sure on it's capacity.
Useless thread.
Unsubscribing to my own thread.
Enjoy trolling each other.
The username may amuse you but to humor you is to go along with whatever you're saying instead of arguing with you.Username humors me
