How can I tell which Creative Sound Blaster Audigy sound card I have?
powerMarkymark
2,164
I had a system built about three weeks ago (see Big Bertha specs in Rigs) and the guy installed a Creative Sound Blaster Audigy sound card in it.
The problem is, is that it is an OEM card and I therefor did not receive any documentation on the card.
The installation CD does not help, it simply says Creative Sound Blaster Audigy. The vendor has the card on his web site Link and it says that it is a Creative Sound Blaster Live Audigy. I have gone to the Creative website and Creative Sound Blaster Live Audigy does not exist!
How can I tell which Creative Sound Blaster Audigy sound card I have? Short of taking the damn thing out of my case that is.
Thanks in advance.
murphy55d
11,542
An Audigy is an Audigy is an Audigy. The only differences are the software package which comes with it, and possible a breakout box with the platinum package. The card itself is the same.
bacillus
14,517
the OEm audigy is essentially the same as the other audigy cards, differing only in not having gold plated connectors!
wfbberzerker
10,423
<< the OEm audigy is essentially the same as the other audigy cards, differing only in not having gold plated connectors! >>
no gold plated connectors?!?! how could they stoop so low?!
murphy55d
11,542
I stand corrected.
Wolfsraider
8,305
does it have the same difference in oem vs retail as sb live value?
ie... different drivers needed?
i had to get mine from a german web site for my sblive value oem;)
hopefully creative worked this one out
yg17
151
the only difference are the connectors and software package. they all use the same drivers
PKRipper1
397
Does all the audio get translated into German? OK. That's not funny.
MasterHoss
2,323
Yeah, you should be good to go. As far as I know, the OEM version lacks the gold plated connectors and any software (as stated by others). To make sure, run the DirectX diagnostics utility --> dxdiag in the run dialog box
Click on the SOUND tab and tell us what's listed as far as Device Name and Driver Name... also are the drviers signed?
