Originally posted by: Engineer
Typically, SAE 30 oil is used for small engines like a lawn mower. 2 cycle oil is to be mixed with the gas and I don't ever recall seeing a 2 cycle oil mower.
Originally posted by: GuitarDaddy
If it were 2 cycle you would know it, you have to mix gas with 2 cycle oil for fuel. Generally older lawnboys, weed wackers and chainsaws are the only 2 cycle's. Just use SAE30 4 cycle oil in the crankcase of your mower.
To specifically answer your question, if it has an oil fill it is a 4 cycle.
It's interesting that a mower (Lawn Boy) would use a 2 cycle engine. The reason for 2 cycle engines is to have the oil mixed in with the gas so that the engine can be lubricated from the fuel and it will be lubricated no matter which position it's placed in (chainsaw can be turned over, up, down, backwards, forwards and it doesn't matter because the oil is in the gas). Must be some other reason that Lawn Boy would want to do that. Personally, I would hate having to mix oil with the gas to mow the lawn, lol!![]()
Originally posted by: Captain Howdy
Well, 2 cycle engines tend to have higher specific output as well, so a lighter engine can make more power. I am pretty sure the lawnboys that had them had small 20" or less decks. Perhaps they were going for light weight?
They're also simpler and cheaper to manufacture.
Originally posted by: GodlessAstronomer
What's this 2/4 'cycle' shit? It's a 2/4 stroke engine. The cycle refers to the full cycle of the engine, so a 2 stroke engine has 2 strokes per cycle, a 4 stroke has 4 strokes per cycle (much like uhohs).
Be sure it doesn't :|
True. No valves, cams, etc. However, I wonder if they are more or less efficient in that it would seem that the incoming fuel would be mixing with the remaining exhaust fumes that are left in the cylinder (4 stroke model obviously removed more as it has an exhaust stroke).
Indeed, in some places (such as my country) there is now a ban in place on producing new two stroke boat engines due to the horrible emissions. You only need to be near a 2-stroke boat, Jetski or lawn mower to confirm the strong odor of unburned hydrocarbons. Nasty.
Welcome to the wonderful world of colloquialisms. Throughout the US the terms "2-cycle" and "2-stroke" are interchangeable in the common vernacular. At least in the US, it is rather excessively pedantic to insist that only "2-stroke" is correct.
ZV
ZV
Curious, why is it called "2 Cycle Oil" instead of "2 Stroke Oil"?
Even oil companies call it 2 cycle and 4 cycle!![]()
ZV
You're agreeing with me.
ZV
ZV
