How can i tell if my Java is 32bit or 64bit?
JEDI
29,391
2,738
control panel -> java -> about -> version 8 update 60
doesn't tell me if it's 32 or 64bit.
or does it not matter?
(I have win 7 pro, 64bit.)
ArisVer
1,345
32
In Programs and Features it says Java 8 Update 60 (64-bit); this on Windows 8.1.
JEDI
29,391
2,738
open a command prompt and type "java -version"
C:\Users\UserName1>java -version
java version "1.8.0_60"
Java(TM) SE Runtime Environment (build 1.8.0_60-b27)
Java HotSpot(TM) 64-Bit Server VM (build 25.60-b23, mixed mode)
so 64bit?
Z15CAM
2,184
64
www.flickr.com
Dude111
1,495
Hmmmm I havent ever done that before.... Im on 1.5.0_04 (I knew that already)
C[color=1]:[/color]\WINDOWS>java -version
java version "1.5.0_04"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_04-b05)
Java HotSpot(TM) Client VM (build 1.5.0_04-b05, mixed mode)
What does 'MIXED MODE' mean??
cubby1223
13,518
42
86
short answer is "MIXED MODE" means remove that outdated and very insecure version of Java and install the latest supported by your OS ;)
