First: UTP, by itself, sucks in the most major way for use as speaker cable. No two ways about it. SuX DeluX(!)
Second: Teflon has not been used for wire insulation for many years, due to the ban on flourocarbons (like freon ... Teflon is ptfe). Thank you, spongehead twit tree-huggers.
When the substitution began (other substances instead of ptfe), they started by migrating (some pair ptfe, some pair with the substitution. Then someone figured out that the velocity factor, per pair, would be different (it was), and they flocked to the Lab (including our Lab) to run tests to see if the new mix (ptfe/non-ptfe) would violate the skew of the cable (some signals arriving in a different time frame from the same source).
Happy news! Skew was within acceptable limits. Now there is no teflon insulation, it's all the substitute stuff, and the skew is still wunnerful.
So there ya go. Go out & buy some nice tire-chain speaker cable for your box.
Scott
