How can I tell how many watts my system is using?
KingstonU
1,405
16
Is there a program for this like CPU-Z or something?
What is the TDP of my 130nm Athlon 64 3200+ ClawHammer? (Rest of PC in signature)
Compared to my 3 year old system, How much less power would a new basic PC with a 65nm CPU with DDR2 ram (I beleive DDR2 uses less power than DDR1), significant at all?
How about a 45nm CPU, DDR3 ram and a Solid State hard drive?
Just curious, thanks
athfbum
183
New PCs today use more power, but they execute tasks more efficiently using the least amount of power they possibly can. However, most of us (when I say us I mean OCers and gamers) don't really care about power consumption except when picking out a PSU and to see how much heat it will put out (more power consumption -> more heat)
A C2D E6600 and 8800GTX use a lot of power, but they have an enormous amount of processing power. The combination allows for the most pleasurable gaming experience which is what most of us aim for.
With a system if you want low power consumption you try to aim for the most performance per watt.
[athfbum]
dfuze
11,953
Look for a program called Overklockulator (I think it's spelled w/ a 'k'). It has a tab that allows you to select components to determine the type of power supply to get.
Operandi
There is no software that can answer that question. You can measure the power from the wall with a kilowatt meter to get the AC power draw -- power consumed by your hardware plus the power loss in your PSU for the AC to DC conversion.
To get a good idea of what each component draws read this SPCR article (Power Distribution within Six PCs).
bob4432
11,727
46
kill-o-watt FTW!!!! you will see exactly how many watts you are pulling from the socket...
KingstonU
1,405
16
I'm not talking about top of the line gaming rigs with 8800GTX and 750Gb harddrives, I'm talking basic systems.
I mean in terms of the TDP of newer CPUs is decreasing as manufacturing process gets in to 65nm and 45nm, we now see 65W and 35W CPUs and below when at idle.
Solid State hard drives use a fraction of the power of regular hard drives
DDR2 memory uses less power than DDR1
bob4432
11,727
46
again, get a kill-o-watt, it will tell you how much you are pulling
aceO07
4,491
Yup. I have a Kill-a-Watt. My desk uses about 190watts. That's 20" DELL LCD, router, dsl modem, speakers, lamp, laptop and the desktop.
ShawnD1
New computers use the same amount of power as old computers. I have a Core2 6600 with a GeForce 7950 and the peak power usage is never over 200W, as measured by my UPS. Idle power consumption is in the ballpark of ~130W.
Contrast that with something like a Pentium 4 or Athlon XP (32-bit) and it's not all that different. Even the original Athlon and Pentium 3 processors took about that much.
