How can I setup dual monitor, mirrored displays with a 9700 pro and hydravision? EDIT! solved it
mcveigh
6,457
All I want is to have the same display on each monitor. but I can' tfigure out how to set it up using ati's hydravision software.
I've done it before w/ matrox and nvidia software but not ati.
edit:
damn that was hard info to find. for fututre reference you have to enable the 2nd display but not check the box to expand the desktop to it.
then make sure the primary monitor is selected and click on the advanced tab.
then click displays. turn on the second dispaly and select the little double square button. it's called clone mode.
if you search the ati help pages for "clone display" you'll find it.
