how can i print a pdf document using my printer?
asad
hi to all
how can i print a pdf document using my printer? ...i can't print any pdf document because the
printer button is disabled in adobe reader 6 ...and when i copy all the text
in the document in the clipboard and past it in the notepad the text doesn't appear.
thanks in advance
Printer works fine in my Adobe Reader 6.x - try uninatall - restart - reinstall, or download the new ver. 7.x and uninstall 6.x then restart and install ver.7.x. Is the print button greyed out on all .pdf files or just one - I think it is possible for PDF document authors to block printing if they want.
.bh.
.bh.
Yup. The author of the PDF document can disable printing among other things (like cut & paste).
Dave
