P phatj Golden Member Mar 21, 2003 1,837 0 0 Oct 5, 2006 #1 so its one of those HTIB deals. I'd like to b e able to watc cable tv and listen to it on the speaker system. i have an old rca tv with a set of rca inputs. but no rca outputs. is it possible?
S sswingle Diamond Member Mar 2, 2000 7,183 45 91 Oct 5, 2006 #2 You need a cable box or VCR, so you can do video out to tv and audio out to another device.
SoulAssassin Diamond Member Feb 1, 2001 6,135 2 0 Oct 5, 2006 #3 yup...cable box ftw. Sign up for digital cable...usually only $10/mo in most places.
YOyoYOhowsDAjello Moderator<br>A/V & Home Theater<br>Elite member Aug 6, 2001 31,205 45 91 Oct 5, 2006 #4 Just checking - you have a set of RCA inputs on the receiver, right? Some of the really POS ones have very limited inputs on them and have an integraded DVD player as pretty much your only source option
T TeeJay1952 Golden Member May 28, 2004 1,532 191 106 Oct 5, 2006 #5 Make sure you set boxtop audio out to advanced.
