How can I get a USB HD to work with both PC and Mac?
GoingUp
16,720
My sister has a one year old laptop with OSX10.2
I just got her a 160GB hard drive for christmas. I want to load up a bunch of pictures and music she has before I give it to her.
I only have PCs. How can I format the drive to make a Mac still able to see it?
Thanks!
HDTVMan
Banned
Apr 28, 2005
1,534
Since your 10.2 better to format with FAT32. 10.2 is flaky with NTFS. 10.3 is better.
I wonder if you partition a section with FAT32 and the rest with NTFS how it would work. First partitiong FAT32. I do this and it comes in very handy when you need a FAT partition because your GHOSTING your OS since ghost boots dont read NTFS.
chcarnage
1,751
Since it's unlikely that your sister is going to reformat the HD, I'd try to use the HFS+ format, because OS X is meant to run with this. If you use another format on a Mac, you lose some functionality (Window sizes and positions, icons I think, and other metadata).
There is some software available to work with HFS+ volumes on a Windows PC, however I don't know how good it is.
HFVExplorer
MacDrive
But the most important thing is to avoid NTFS, it's a badly documented or patent tied format that works horribly on the Mac, last time I checked Macs didn't have write support for it.
erwos
4,778
I was under the impression that MacOS X just stored the metadata in a different way, not that it discarded it.
I'd go with FAT32/VFAT for this one.
-Erwos
GoingUp
16,720
Can I format all 160GB as one Fat32 partition?
I forget the size limit of a fat 32 partition. Is it 32GB?
HDTVMan
Banned
Apr 28, 2005
1,534
There is a FAT48 hack but I dont recommend it. I can almost guarantee the mac wont understand it and will most certainly have problems.
I have messed with HFS without much luck. Too much conversion.
I recommend formatting the first partition FAT32 to the max and then the rest NTFS.
GoingUp
16,720
What about burning everything on DVDs, taking the DVDs and HD into compusa and using the in store MACs to transfer everything?
