techs
I use a Sandisk Cruzer 2gb. flash drive on a lot of machines with two of them being Windows Vista machines. Unless I do the "Safely remove hardware" seequence before I unplug it on a Windows XP machine, when I then plug it into a Windows Vista machine it says my disk needs to be checked, or I can just continue without scanning.
I have scanned many times and have never found an error.
Can I disable the error checking on the Vista machines? Or perhaps do something to the drive to disable the error checking?
Thanks.
Thanks.
